Poor quality pixelated text in Menus using DVD Studio Pro.
COW Forums : DVD Authoring
Hazestudios
on Mar 13, 2008 at 3:19:39 am
Hi there,
I'm using DVD Studio Pro. I create menus in Photoshop and export flattened .psd files.
I work in PAL. This problem is worse in 16x9 (anamorphic).
I create the menus at the true original res of 1024x576. When the menus are imported into DVD Studio Pro the text becomes jagged and pixelated. I understand that non-square pixels are causing this, but I don't know of a solution.
What is the best way to bring menus and text into DVD Studio Pro?
I have searched a lot and noone has a great solution.
Thanks heaps,
Mike
Bouke Vahl
Re: Poor quality pixelated text in Menus using DVD Studio Pro.
on Mar 14, 2008 at 4:13:51 pm
'true' 16 : 9 video is 720 * 576 in Pal, non-square pixels
(same res as 4:3, other pixel aspect ration)
In the latest versions of Photoshop, you can set it to non-square 16:9 Pal.
Or, scale down the images in Photoshop to 720 x 576 before bringing them in DVD SP
Bouke
http://www.videoToolShed.com
smart tools for video pro's
Bridget O'Leary
on Mar 25, 2008 at 12:06:49 pm
Mike,
I had a simular problem previously. After much searching on this site and Apple's forums I found out that you can import PSD menus at a higher resolution than I first thought - 300dpi.
Also what really helped was bringing the menu in as 720x576 and then setting the menu to 16x9 once imported into DVD Studio Pro. This meant I created the menu as a 1024x576 graphic, then resized it to 720x576 so it appears anamorphic ready for importing into DVD Studio Pro.
One other small trick is to add a 1 - 3 pixel 'blur' in photoshop.
Regards
Bridget
Girshon Rutstein
on Mar 27, 2008 at 1:13:32 am
Import Photoshop File into your Editing application. Create 5 sec movie and export as Animation Codec
It will look great!
