Scenarist rejecting restroed assets
COW Forums : DVD Authoring
Benn Gunn
on Feb 5, 2008 at 12:49:17 pm
I just restored an old Creator project using Retrospect. I need to use the video and audio assets to build anew bversion of the project. However, the video assets will not import in Scenarist. They are Creator encodes so I have had to join the mpeg segements in MS DOS to create a stream which Scenarist should recognise. I have always done this in the past when using Creator encodes and never had problems. This time I get the following error message (Error This video has unknown picture type. File offset = 335556041. [C:BHprog1.mpv]) and Scenarist rejects the asset.
Is this just a corrupt restore or is there anything else I can do? I have run it through Procoder to create a new mpeg and this imports without issue, and the origianl file can be played in software players such as Cineplayer and Nero.
Max Kovalsky
Re: Scenarist rejecting restroed assets
on Feb 5, 2008 at 1:15:19 pm
It must not like the header. Try running your mpeg though ReStream. You can also try joining the mpegs within Scenarist by using the "multi-data asset" function.
Max
Author
New York
Area4.tv
Benn Gunn
on Feb 5, 2008 at 2:00:53 pm
Already tried all that in the meantime! Neither worked out for me.
