DVD Pro Authoring for BD
COW Forums : DVD Authoring
Shanika
on Jan 18, 2008 at 11:56:19 pm
Reading so much about which authoring system to use for authoring Blue Ray DVDs, I'm wondering why not DVD Pro, which is supposed to do it. Couldn't I author it with DVD Pro and then burn it with Toast Platinum? I'm asking this because I need to buy BD Burner soon and I'm editing with FC Studio 2. Do you have any advice and suggestions.
Dusan
Robert Ober
Re: DVD Pro Authoring for BD
on Jan 19, 2008 at 2:48:32 am
Nope, DVDSP will NOT author Blu-Ray. It will author HD-DVD. For an Intel Mac you probably want Encore CS3 which is part of Adobe Premier Pro CS3. It is no longer sold separately. If like me you are on a G5, you are out of luck. There is NO authoring solution for PowerPC Macs that I can find. Toast 7 & 8 can burn Blu-Ray data discs and I am using it for that.
By the way, the Panasonic SW-5582 works well in my G5. I bought it from OWC at macsales.com.
Good Luck,
Robert
Jason Crawford
on Feb 15, 2008 at 1:57:47 am
BD authoring is much more complex then DVD authoring as far as the "guts" go, that is only if you want seamless menus. You can actually use DVDit and a product by Ulead if you want basic old school menus (the ones we do now with DVD). All else is another story. There are three options: HDMV mode which is using 8-bit images and muxing them into the streams and also adding basic logic, such as simple animations. Then there is BD-J mode with is full Java coding. The 3rd option is a combo of HDMV mode and BD-J mode, a good example is the movie Cars. This uses both
"Imagination is more important than knowledge" -Albert Einstein
