Audio Tracks in Scenarist
COW Forums : DVD Authoring
Victoria Ellis
on Jan 7, 2008 at 9:42:51 pm
I am trying to author a DVD in Scenarist where, on the title menu, there is an option to play the video track without an audio commentary, or with it.
I have imported both audio streams into the video track, but I cannot figure out how to make the "play with audio commentary" button play the video with the audio 2 track.
Can anyone tell me how to do this, or have any suggestions on how to change the menu structure so I can?
Many thanks,
Victoria
Eric Pautsch
Re: Audio Tracks in Scenarist
on Jan 7, 2008 at 10:44:07 pm
There are several different way to do the same thing in Scenarist but this is the way I do it:
Since your in the VMG, you can't set the audio stream from there. I'd give a register a value depending on which button was chosen. Then set the stream playback in the Pre-Command of the PGC which contains the movie based on the value of the register.
Max Kovalsky
on Jan 8, 2008 at 1:42:45 am
That's what I'd recommend as well. Except if you want to track your setting when jumping back and forth within VMG, I'd write variable, set stream in the post-command of your menu, and enforce the setting again in the pre-command of your title PGC.
Max
Author
New York
Area4.tv
Victoria Ellis
on Jan 8, 2008 at 9:11:09 am
Thanks - theoretically that makes sense, but how do I actually do that? Sorry, but I haven't done any complicated projects before!
Thank you!
Victoria
Max Kovalsky
on Jan 8, 2008 at 11:31:56 am
In your button commands do this:
1. Mov GPRM 1, 0, link indirect, post-command of this PGC
2. Mov GPRM 1, 1, link indirect, post-command of this PGC
GPRM 1 not effectively carries your setting.
In the post-command of that PGC (your menu), do this:
1. Set audio stream to GPRM 1, link to title
In the pre-command of your title PGC, do this:
Max
Author
New York
Area4.tv
Clint Nitkiewicz Hernandez
on Jan 18, 2008 at 12:39:37 am
Hey Victoria, have fun with the links below. They should help a lot.
Check out the other pages also for reference.
http://www.dvd-replica.com/DVD/setstn.php
http://www.dvd-replica.com/DVD/vmgroups.php
Good luck.
http://www.newelementproductions.com
Film-Maker/ Blu-ray Author/ Compositor
