DVD Authoring Workflow
COW Forums : DVD Authoring
skauty
on Dec 7, 2007 at 5:01:28 pm
Just curious if anyone has a specific workflow that they think works really well for outputing to DVD. I'm using mostly After Effects for motion graphics and am looking for a good, cost effective solution for getting work to dvd, ie. AE to Sorenson Squeeze to DVD-lab. Does anyone have software they're particularly fond of?
Alessio Gemma
Re: DVD Authoring Workflow
on Dec 9, 2007 at 8:25:52 pm
Hi, in AE I always export in uncompressed or high bit rate codec. Now, I use the last Apple ProRes Codec, but before I used to export in Animation codec: ProRes has the same quality of Animation but at lower bit rates (smaller exported files)
Then, I use Compressor (but you can use Squeeze or something like that) to obtain the MPEG2 for your DVDs.
Regards,
Alessio
Murphy Thelen
on Jul 28, 2014 at 7:43:08 pm
AE CS6-->Output ProRes 422(HQ)--> Encore CS6--> Output ISO--> Burn ISO to disk using Toast and Blu-ray burner (even if authoring an SD dvd).
Works like a charm.
