flickering problems
COW Forums : DVD Authoring
flickering problems
on Dec 5, 2007 at 10:18:47 am
Alessio Gemma
Re: flickering problems
on Dec 9, 2007 at 8:31:29 pm
Hi, I'm sure you see a "strobe" effect, no a "flicker" effect: it's because you don't set the field dominance correctly.
In your source material is NTSC, I think you have to select "Bottom field first" or "Lower" for field rendering (I'm in the PAL land, here it's the opposite: "Top field first" or "Upper").
If your source is progressive: well, you can encode it as progressive, but your DVD player must be able to read progressive source. Anyway, it's better to remain in the interlaced world and you have to "interlace" your video.
© 2018 All Rights Reserved
