Trying to make a HD DVD out of Ulead VideoStudio 11
COW Forums : DVD Authoring
Peter Corbett
on Oct 30, 2007 at 9:14:46 pm
Not having much luck here trying to create a HD DVD compliant DVD out of Videostudio 11. I've read that lots of guys have had success burning to standard DVD-R discs using the Ulead program.
I can get the 1920x1080 MPEG2 to play and burn correctly in VS but when I try to play the disc in a Toshiba HD DVD player, I get a message saying, "The disc is not DVD format". I am trying to do the disc in 25fps as it came from a 25fps master. I've also reencoded the original as a 30fps master to see if that had any affect but it didn't. Plus I need to make the disc endless looping for a show.
Hmmm.......
Peter
Peter Corbett
Powerhouse Productions
http://www.php.com.au
Max @ Area 4
Re: Trying to make a HD DVD out of Ulead VideoStudio 11
on Oct 30, 2007 at 11:57:57 pm
HD DVD spec only allows for 29.97 video. Make sure that's what you're encoding.
Max
Author
New York
Area4.tv
Peter Corbett
on Oct 31, 2007 at 12:26:57 am
Thanks Max, I'll redo it at 29.97. Because my original is 25fps, I may have a problem there. I may have to see if I can find a Tivo-style kiosk media player that can loop HD through HDMI.
Cheers,
Peter
