Looking for an experienced replicator in NY
COW Forums : DVD Authoring
Michael
on Oct 18, 2007 at 1:47:43 pm
The DVD I'm finishing has a pretty high bit rate and doesn't play smoothly on all the players when burned on the Mac. However from what I heard, if you go a glass master route, things change. I'd like to find someone who would be able to check my master against possible errors and pretty much give me either a green light or some pointers as to what to possibly change. Any recommendations? NY is not a must if you know someone absolutely outstanding :)
Max @ Area 4
Re: Looking for an experienced replicator in NY
on Oct 18, 2007 at 1:54:18 pm
Michael,
Unless you have a DLT drive set-up, you'll have to find a replicator that will accept your DDP image on a drive. Otherwise, your pressed DVD's will for sure have the same glitches as your DVD-R.
Part of the replication process involves making the glass master and pressing a few discs from it. If the discs do not play properly, you'll have to resubmit the DDP and pay for another glass master.
We're in NY, by the way, and take a look at your DVD.
Max
Author
New York
Area4.tv
