Bitvice won't compress
COW Forums : DVD Authoring
Christopher Pearson
on Sep 2, 2007 at 7:08:06 pm
I create all my MPEG-2's using Bitvice 1.6 and never had a problem until now. I've got a Quicktime movie that is giving me trouble. I get an error from Bitvice stating, "Unable to create file for output MPEG-2 movie".
The QT originated from DV, but I no idea how it was captured to QT (The file is Component Y'CbCr). The QT Movie Inspector tells me the file format is this:
Photo Sharing and Video Hosting at Photobucket
In attempt to convert the clip to something usable, I've tried exporting it from FinalCut as a normal DV NTSC 720X480 and Bitvice still wouldn't compress it.
Any ideas would be GREATLY appreciated.
Thanks in advance...
Roger Andersson
Re: Bitvice won't compress
on Sep 9, 2007 at 4:22:22 pm
This happens when BitVice for some reason is not allowed, by the OS, to create a new .m2v file in the folder you selected. Check that your user has write permissions for the folder.
Since BitVice is denied to open a new file, there is no point in starting an encoding session, because there is no way to save the result.
Roger Andersson / Innobits AB Sweden
© 2018 All Rights Reserved
