SONY XDCAM compression for SD DVD
COW Forums : DVD Authoring
Kevin Gonzales
on Aug 24, 2007 at 3:49:48 am
Hi:
I am trying to find the best compression from a Sony XDCAM timeline in FCP for a SD DVD. I've used the H2.64 at NTSC 16:9 and it worked great. Then I dropped that file into compressor and used a preset for converting the H2.64 file to an MPEG 2. It all works great but the only problem is that it is still a freaking huge file even after it is compressed to MPEG 2. I used 150 fastest encode for converting the H2.64 file. Is there another way I can compress the XDCAM timeline so that it is smaller but still good quality. Would love any help or suggestions.
eric
Re: SONY XDCAM compression for SD DVD
by
on Aug 24, 2007 at 4:06:03 am
Why are you going to H264 before encoding to MPEG2? Yur making an extra step which is not needed or desirable. Just encode directly from the timeline using compressor to MPEG2. How large is the file? How long is the timeline.
Noah Kadner
on Aug 24, 2007 at 1:53:40 pm
Send to compressor directly from FCP and apply one of the high quality DVD presets. No reason whatsoever to stop over at H.264 first.
Noah
Unlock the secrets of the DVX100 and now Apple Color!
http://www.callboxlive.com
