Which way is better?
COW Forums : DVD Authoring
shahram
on Jul 15, 2007 at 9:06:53 pm
Hello
I have a problem, can anybody help me?
I have a DVD-Video and I want to edit it in editing application (Edius) and then again I want to create new DVD-Video from it with new menu and subtitle.
Since my capture card has been damaged and right now I just have IEEE 1394, I think I can do it in two ways;
1- capture DVD-Video by IEEE 1394 as an AVI file and edit it in Edius and then export final video as a MPEG2 file and in the next stage take them to DVD authoring application and create DVD-Video with new menu and subtitle.
2- Importing Vob file directly to Edius(it support vob files) and edit it, then export final video as a MPEG2 file and then send them to DVD authoring application for creating new DVD-Video.
In your opinion which way is better? What would you do if you were me?
Quality and resolution are most important factor for me, I don
Noah Kadner
Re: Which way is better?
on Jul 15, 2007 at 9:13:51 pm
Is it a copy-protected, commercial DVD or one you authored?
Noah
Unlock the secrets of the DVX100 and Final Cut Pro!
http://www.callboxlive.com
shahram
on Jul 16, 2007 at 3:58:44 am
No it is not copy protected, I can capture it by IEEE1394 and can rip it to hard too but I am not sure which way is the best?
Noah Kadner
on Jul 16, 2007 at 5:09:17 am
I'd try to find the original media- DVD is a horrible source for good quality. I'd go with whatever looked best on a disc by disc basis otherwise. DVD to DV is going to be quickest.
Noah
George W.
on Jul 16, 2007 at 2:31:16 pm
What type of "Editing" do you plan to do? Straight cuts, or something more such as compositing and adding titles, etc...?
Regards,
George
shahram
on Jul 17, 2007 at 9:59:50 am
Noah, there is no original media, this DVD-video is all we have.
Yes George, I want to remove and add some part of video and change entire audio of video, I might use some filter like color correction (not so much) and after that I want to export it to Adobe Encore DVD for authoring.
Regards
shahram
George W.
on Jul 17, 2007 at 10:49:14 am
What is the resolution of your current DVD? If it's anything but 720x480/576 (NTSC/PAL), then I believe Encore will re-encode (someone correct me if I am wrong). In other words, some DVD Recorders use 704x480, but Encore will re-encode to be 720x480 (I do not know if Encore CS3 does this).
If you find you do have a resolution that forces Encore to always re-encode, you might be better off converting to a more edit-friendly format (dv .avi as you have suggested). Then encoding properly for Encore (try to minimze the number of re-encodes).
Regards,
George
shahram
on Jul 17, 2007 at 10:48:15 pm
Resolution is 720X480 NTSC, Encore2 will re-encode it but I don
