Creating compatible DVDs: Stuttering & Colour Temperature
COW Forums : DVD Authoring
cowcow
Bill in Toronto
on Jun 21, 2007 at 11:32:13 am
There are several parts to my inquiry. Personal experience very appreciated, but also any FAQ or bibliography.
1. In your experience which is the best type of original media for creating a DVD intended for mass production and potentially glass mastering? e.g. DVD-R; DVD+R, et al.
2. Is there a brand of DVD media which is more reliable than others. (I've generally used Ridata.)
3. I have well over a GIG of RAM and no difficulty in playing an authored DVD without stuttering. However, some clients have older pc systems with CRT monitors, age unknown. They complain about the following:
a. Colour of some animation displayed on their monitor is too dark. (Just fine on my Samsung 713v or my NEC MultiSync LCD 1700v.)
b. Either the DVD stutters on the computer right from the beginning (but never on my system or my standalone Toshiba player); or after playing several selections, there is stuttering.
**The amount of material - video and also animation - is under an hour, but I guess my question is how do you ensure to avoid the above complaints where the age of the computing system is not known?
**How should technical instructions be expressed which can accompany a DVD indicating a cut off of compatibility, or "plays best..." under these conditions.
Cheers, and thanks so much for your collective wisdom.
Bill in Toronto
Borjis
Re: Creating compatible DVDs: Stuttering & Colour Temperature
on Jun 29, 2007 at 4:35:54 am
[Bill in Toronto] "1. In your experience which is the best type of original media for creating a DVD intended for mass production and potentially glass mastering? e.g. DVD-R; DVD+R, et al.
Verbatim
Verbatim
Did I mention Verbatim? ;)
Others may debate this but I find DVD-R to be the most
compatible and I author tens of hundreds of unique titles each year.
For discs going in for replication source, burn at the lowest
speed possible to keep the errors down to a minimum and burn
at least 2 of them to send in case they have problems with one
See #1
I used Ridata/Ritek for 4 years. They were great reliable media.
Recently they've taken a turn for the worse, I had more bad discs
(good discs gone bad and way less compatible)recently. the quality control clearly went south and for a few cents more you can have ultra
reliable Verbatims.
b. Either the DVD stutters on the computer right from the beginning (but never on my system or my standalone Toshiba player); or after playing several selections, there is stuttering."
Don't worry about monitor levels, most peoples monitors are way
out of wack, have worn out phosphors that can't pump out the
contrast like they used to. Flat panels are always brighter
so just make sure it looks right on your various displays YOU test
them on.
to minimize stuttering:
ALWAYS encode the audio with Dolby .ac3 at 256kbps, any less
doesn't sound quite as nice to me at least, any more is overkill.
Encode your video so that your average or constant bit rate is between 5 and 6.5mbps Never go beyond 7mbps unless your replicating. DVD-R media has almost no error correction and can't handle the full DVD bandwidth potential set top & pc players. Replicated can.
Here endith the lesson. :)
Bill in Toronto
on Jul 25, 2007 at 2:38:21 pm
I greatly appreciated your help, Borjis. Thanks for the lesson, it was useful learning.
Cheers,
Bill in Toronto
