could this be a dvd sp issue?
COW Forums : DVD Authoring
Antonio Atzei
on Jun 12, 2007 at 12:39:02 pm
I may been asking the wrong question before so here I go again.
Let`s say that you want to cut down the ammount of light/luminosity in your final project. How should I go about?
Apparently every attempt give`s me the same outcome.
A- cutting the ammount of whites or mids
B- cutting down the opacity
I also tried some filters with no success
The bottom line is that I need to lower the luminosity of the clip and make sure that during output to sd dvd keeps that setting.
Any suggestion please, or point e in the right direction.
The dvd looks fantastic it`s only to bright.
Antonio Atzei
Noah Kadner
Re: could this be a dvd sp issue?
on Jun 13, 2007 at 4:54:25 pm
Hmm- you can use the color correction and broadcast safe in FCP to bring luma down. There's a slight shift when you got out to DVD maybe a point or two in IRE but nothing major. You can also apply an overall gamma filter in Compressor to help.
Unlock the secrets of the DVX100 and Final Cut Pro!
© 2018 All Rights Reserved
