Deinterlacing or pixel aspect ration trouble...?
COW Forums : DVD Authoring
twotimes_170
on Jun 1, 2007 at 7:17:47 am
I am importing betaSp content with a 16:9 pixel aspect ratio.
I run the signal through a Dac 200.
I get a dv avi file in 4:3. This i guess needs to be corrected to the right aspect ratio.
At this point i see small vertical black lines around moving objects, but i understand this is normal.
The next thing i do, is importing the file to Sorensen squeeze and then to Sonic dvd-it. However i cant seem to get rid of the black lines..! Ive tried all reasonable and unreasonable settings i can think of. If i squeeze it to a 4:3 aspect ratio and then use the de-interlace setting i vlc, the lines disappear.
How do i get rid of the black lines. Ive search this and other forums with no luck.
