Problems with 16:9 PAL authoring
COW Forums : DVD Authoring
on May 11, 2007 at 2:41:42 am
Hey all
New to this, but unfortunately client wants an authored dvd asap, and im having some difficulty here!
I have a some motion graphics that i have rendered out of AE as 720x576 (PAL widescreen pixels). Now I have gone in to try and author this, and for some reason the authored dvd clips the SIDES of the clip when played on a tv (both widescreen and standard 4:3) but when played on a computer's dvd player, the whole clip is visible.
I have set the dvd project as PAL Widescreen, and have interpreted the quicktime as 720x576 16:9 pixels.
What am i missing here. You'd think that this should be pretty straight forward but i have tried everything, and nothing is working!
Please help
Bill Stephan
Re: Problems with 16:9 PAL authoring
on May 11, 2007 at 3:39:29 pm
It's tough to assist when we don't know what authoring software you are using.
If you exported from AE with an anamorphic squish, probably something in the authoring is not flagged correctly as 16:9 or Wide. It sounds like you are in Pan/Scan mode, which would cut off the sides upon playback.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
© 2018 All Rights Reserved
