dvd studio pro - movie won't simulate under story marker
COW Forums : DVD Authoring
3dmuscle
on Apr 16, 2007 at 8:25:39 pm
I thought i could figure this one out by myself but so far no success.
I have a track with 38 short movies and using story markers so i can have the option of playing all or just single movies. My problem is 2 of the movies do not play through the story markers (does not simulate as well), it stays black and only the audio plays. I already tried everything, even rebuilding the track, once it worked but as soon as i exited DVD studio and reopened the file, same problem.
It seems the movies themselves are fine, the marker on the track also works since i can simulate but the story marker accessing that track seems to be the problem
Any help is greatly appreciated
eric
Re: dvd studio pro - movie won't simulate under story marker
by
on Apr 16, 2007 at 10:36:01 pm
Hi
I've had this problem as well some times as well. Build a disc and it usually works fine. Making a new project usually helps the issue.
3dmuscle
on Apr 17, 2007 at 1:00:25 pm
Thanks Eric, i will try the rebuild, i really hope it works, it would be a lot of work to redo the trakks and stories
Thanks again
3dmuscle
on Apr 19, 2007 at 2:40:04 pm
I tried fixing the track but still there was one movie not playing/simulating. I created an image on my harddrive and tested it out and it plays fine, so not sure what the problem is.
thanks
eric
by
on Apr 19, 2007 at 6:29:54 pm
Did you try moving your tracks in different order in your outline? I usually place my track from the smallest on top to the largest on the bottom and this usually works. I think this is some kind of minor bug that needs fixing up as long as you have a working disc image your good to go.
