Intellidisc: Possible to link to folder?
COW Forums : DVD Authoring
Tore Jonssen
on Mar 16, 2007 at 7:45:36 am
From a menu button; Is it possible to link to a folder on the DVD, containing several documents? I know eDVD can do this...
Frank_Guys
Re: Intellidisc: Possible to link to folder?
on Mar 18, 2007 at 8:05:12 pm
If you want to link to a folder you will need to use a valid URL path to the folder such as the following:
file://C:/Program Files/Netblender/Intellidisc
This will link to the Intellidisc foler. Here are the steps:
1. Select the Menu Button you want to apply the behavior to.
2. Use the HTML Behavior: "Open Browser Window"
3. Then the URL like the one above: "file://C:/Program Files/Netblender/Intellidisc".
(you don't have to set the size or position only if you want.)
That is it.
bluestupa
on Jun 18, 2007 at 11:10:17 am
Wait, how does that link to a file on the DVD?!? I am pulling my hair out with this and other quirks if intellidisc. But I had a wonderful edvd project built only to find out that the target was locked down PCS, so i have to somehow port this eDVD project to an intelldisc one. I am going nuts with all the bugs. Can u help answer a few questions if you have successfully built a DVD with this tool?
BS in Nepal
Tore Jonssen
on Jun 18, 2007 at 11:39:07 am
I ended up buying eDVD for my project. Successfully authored a DVD-9 with 3,5 hours of video and 1,6 GB of documents in various formats and have distributed about 1.000 copies without a single complaint from the client. Gave up the Intellidisc after discovering it doesn't support files bigger than about 75 MB....
