DVD SP language codes?
COW Forums : DVD Authoring
robert
on Mar 11, 2007 at 10:12:00 pm
Hi, I trying to burn a project and keep getting a failure note right off the bat saying " language codes for 'English ' and ' English-2' must differ " . I'm not usuing any scripts,subtitles or storys.. pretty straigt forward. The only thing I'm doing differently than usual is using AIFF audio instead of dolby 2.0 because the project is small enough. Any hints on this one would be greatly appreciated!!
Rob
eric
Re: DVD SP language codes?
by
on Mar 12, 2007 at 12:50:34 am
This happens often..so don't feel bad :) You've duplicated your original language by mistake. Look in the Outline at the bottom. There you'll see "English" & "English-1". Delete "English-1" and try another build.
Eric
robert
on Mar 15, 2007 at 9:14:09 pm
Thanks for the info. Before I discovered your response, I started again from scratch and fortunately didn't make the same error.
I am not clear what you mean by the "outline" on the bottom. I couldn't find it.
If you happen to see this could you elaborate a little on where it is? I'd love to find a better way than having to start over!
Thanks, Rob
