File size/bit rate of dvcpro 1080 60i vs dvcpro 720p?
COW Forums : DVD Authoring
sliphost005
on Jan 29, 2007 at 6:10:49 pm
Recently, I took some HDcam footage in (transfered from 35mm film) to get transfered to DVCpro HD 1080 60i so that I could edit it on my own system (FCP). The first time they made a 720 p copy instead so I had to take it back it to get redone to my specs (dvcpro 1080 60i). Curiously when I brought my hard drive home with the new dvcpro1080 60i footage, the overall file size (approx. 20 min. of footage) was the same as the 720 copy they had mistakenly made earlier (22.6 G). I fully expected a larger file size as the data rate would be higher. Am I missing something here? Do you think that they simply uprezed the 720p version? or?
Borjis
Re: File size/bit rate of dvcpro 1080 60i vs dvcpro 720p?
on Jan 29, 2007 at 11:04:54 pm
well have you opened it in fcp?
It could very well be that the data rate of either is the same so it can run over firewire.
Arniepix
on Jan 30, 2007 at 12:07:25 am
The data rate on DVCPro HD is 100Mbps, regardless of whether it's 1080 or 720.
Tinx Chan
on Sep 26, 2008 at 7:53:58 pm
does that mean that 720p, dvcproHD is less compressed, therefore having higher quality than 1080?
Max Kovalsky
on Sep 28, 2008 at 2:54:09 am
Yes, but the obvious trade-off is resolution. Which means that when viewed on a 40"or bigger monitor, both formats will look identical.
Max
Blu-ray author/producer
New York
Area4.tv
