Authoring DVD... should I use Bottom Field First or Progressive?
COW Forums : DVD Authoring
rdomalpalli
on Jan 29, 2007 at 11:13:05 am
Hi All,
I'm writing MPeg-2 files to Author a DVD, and I'm using Compressor.
My input is a Quicktime movie Uncompressed 4:2:2, 1920x1080p.
In compressor, for the Format, should I choose Automatic / Bottom Field First / Progressive?
The DVD will be viewed on TV's at home. So I guess, my question is, are most TV's now-a-days Progressive or Interlaced?
Thanks in advance for your reply.
Regards,
Rajnesh
Frippy
Re: Authoring DVD... should I use Bottom Field First or Progressive?
on Jan 29, 2007 at 1:55:03 pm
If source video is Progressive you can set bottom or top.
"Progressive" flag is not DVD-VIDEO standart
Danny2007
on Jan 31, 2007 at 12:53:00 pm
CRT based TVs are interlaced (some have a progressive/deinterlacing option)
Plasma & LCDs are progressive.
As such if you encode to progressive it will look great on the Plasma/LCDs but possibly jerky on the CRTs, if you encode to interlaced there'll be a slight drop in quality on both types of TV.
If it were down to me, I'd encode to progressive as most people I know use a Plasma and pretty well all modern DVD players have progressive support (I'm in the UK so you mileage may vary)
http://www.dvddemystified.com/dvdfaq.html
