Replication problem, who's fault?
COW Forums : DVD Authoring
stoofercat
on Dec 13, 2006 at 9:20:21 am
I had someone author a dvd for me, the dvd was dvd9 so he exported it to (2) DLT and then burnt me a couple of copies of the film on dvd9r, the DLT's were then sent to the replicator and the burnt discs sent to me, the burnt discs worked fine but when I took delivery of the manufactured discs they did not work properly, firstly one of the buttons on the main menu did not work, secondly at 1 hour 24 minutes into the film it goes pixilated and when it clears the film is about 2 minutes foward from where it should be (the counter on the player does not skip).
I have been in discusion with the manufacturers and they were saying it was an authoring problem but I argued because the burnt discs work fine! They have just sent me an email saying that their test shows: 'Line 193 and 197 marks error - wrong address - error of authoring software or of the creator of the authoring.'
I could possible accept this but the guy that authored the disc told me that he exported to dlt and as soon as that finished he exported exactly the same info to an iso image from which he burnt me a couple of discs which work fine.
The manufacturers also sent a master report which I have cut and pasted here:
DVD inserted: "J:VIDEO_TS"
DVD inserted: ""; Provider: ULEAD-DVD
DVD inserted: Resetting all GPRMs to 0.
DVD inserted: Initializing the SPRMs to default/setup values.
------> Entering VMG , First-Play PGC
-- pre 1 : Set gprm(14) =(mov) 255
-> gprm(14) = 255 (0x00FF)
-- pre 2 : Set gprm(15) =(mov) 255
-> gprm(15) = 255 (0x00FF)
-- pre 3 : Set gprm(7) =(mov) 1
-> gprm(7) = 1 (0x0001)
-- pre 4 : Set gprm(0) =(mov) 5
-> gprm(0) = 5 (0x0005)
-- pre 5 : Set gprm(9) =(mov) 0
-> gprm(9) = 0 (0x0000)
-- pre 6 : (SetHL_BTN) Set Highlighted Button =(mov) 1024 (button 1)
-> sprm(8:Highlighted button number) = 1024 (0x0400) = button 1
-- pre 7 : (JumpSS) Jump to VMGM PGC 5
------> Entering VMGM , LU 1 (--) , 5 (0:46) 3b.
-- pre 1 : if ( gprm(0) > 5 ) then { LinkPGCN PGC 6 }
if ( 5 > 5 ) : false.
-- pre 2 : Set gprm(0) =(mov) 0
-> gprm(0) = 0 (0x0000)
-- pre 3 : Set gprm(2) =(mov) 0
-> gprm(2) = 0 (0x0000)
-- pre 4 : Set gprm(3) =(mov) 0
-> gprm(3) = 0 (0x0000)
-- pre 5 : Set gprm(4) =(mov) 0
-> gprm(4) = 0 (0x0000)
-- pre 6 : Set gprm(8) =(mov) 0
-> gprm(8) = 0 (0x0000)
******* Start playback VMGM , LU 1 (--) , 5 (0:46) 3b....
******* Playing Program 1, Cell 1 (0:46.00) (3 buttons)
-> sprm(8:Highlighted button number) = 2048 (0x0800) = button 2
Selected menu button: 2
-- button : Set gprm(0) =(mov) 15 ; LinkPGCN PGC 15
-> gprm(0) = 15 (0x000F)
------> Entering VMGM , LU 1 (--) , 15 (dummy)
-- pre 1 : if ( gprm(0) > 15 ) then { LinkPGCN PGC 16 }
if ( 15 > 15 ) : false.
-- pre 2 : Set gprm(6) =(mov) 15
-> gprm(6) = 15 (0x000F)
-- pre 3 : Set gprm(4) =(mov) 5
-> gprm(4) = 5 (0x0005)
-- pre 4 : Set gprm(2) =(mov) 2
-> gprm(2) = 2 (0x0002)
******* Dummy PGC: no cell to play.
-- post 1 : if ( gprm(2) != 2 ) then { Goto line 11 }
if ( 2 != 2 ) : false.
-- post 2 : if ( gprm(3) != 0 ) then { Goto line 11 }
if ( 0 != 0 ) : false.
-- post 3 : Set gprm(3) =(mov) 1
-> gprm(3) = 1 (0x0001)
-- post 4 : Set gprm(7) =(mov) 3
-> gprm(7) = 3 (0x0003)
-- post 5 : Set gprm(9) =(mov) 1
-> gprm(9) = 1 (0x0001)
-- post 6 : Set gprm(10) =(mov) 1
-> gprm(10) = 1 (0x0001)
-- post 7 : Set gprm(11) =(mov) 39
-> gprm(11) = 39 (0x0027)
-- post 8 : Set gprm(5) =(mov) 1
-> gprm(5) = 1 (0x0001)
-- post 9 : Set gprm(0) =(mov) 0
-- post 10 : (JumpSS) Jump to VTSM 1, Root menu (TTN 1)
-> sprm(5:Title number in VTS) = 1 (0x0001)
------> Entering VTSM 1 , LU 1 (--) , 1 (dummy) RootM
-- pre 1 : if ( gprm(0) > 1 ) then { LinkPGCN PGC 2 }
if ( 0 > 1 ) : false.
-- pre 2 : if ( gprm(14) == 255 ) then { Goto line 19 }
if ( 255 == 255 ) : true.
-- pre 19 : if ( gprm(15) == 255 ) then { Goto line 84 }
-- pre 84 : NOP
-- pre 85 : Set gprm(0) =(mov) 2 ; LinkPGCN PGC 2
-> gprm(0) = 2 (0x0002)
------> Entering VTSM 1 , LU 1 (--) , 2 (dummy)
-- pre 1 : if ( gprm(0) > 2 ) then { LinkPGCN PGC 3 }
if ( 2 > 2 ) : false.
-- pre 2 : if ( gprm(4) == 0 ) then { Goto line 8 }
if ( 5 == 0 ) : false.
-- pre 3 : if ( gprm(5) != 1 ) then { Goto line 7 }
if ( 1 != 1 ) : false.
-- pre 4 : Set gprm(5) =(mov) 0
-> gprm(5) = 0 (0x0000)
-- pre 5 : if ( gprm(5) == 0 ) then { Goto line 12 }
if ( 0 == 0 ) : true.
-- pre 12 : if ( gprm(7) == 3 ) then { Set gprm(0) =(mov) 3 }
if ( 3 == 3 ) : true.
-> gprm(0) = 3 (0x0003)
-- pre 13 : if ( gprm(7) == 3 ) then { LinkPGCN PGC 3 }
------> Entering VTSM 1 , LU 1 (--) , 3 (dummy)
-- pre 1 : if ( gprm(0) > 3 ) then { LinkPGCN PGC 4 }
if ( 3 > 3 ) : false.
-- pre 2 : if ( gprm(7) == 3 ) then { Set gprm(0) =(mov) 4 }
-> gprm(0) = 4 (0x0004)
-- pre 3 : if ( gprm(7) == 3 ) then { LinkPGCN PGC 4 }
------> Entering VTSM 1 , LU 1 (--) , 4 (dummy)
-- pre 1 : if ( gprm(0) > 4 ) then { LinkPGCN PGC 5 }
if ( 4 > 4 ) : false.
-- pre 2 : NOP
-- pre 3 : NOP
-- pre 4 : Set gprm(0) =(mov) 0
-- pre 5 : if ( gprm(11) != 1 ) then { Goto line 7 }
if ( 39 != 1 ) : true.
-- pre 7 : if ( gprm(11) != 2 ) then { Goto line 9 }
if ( 39 != 2 ) : true.
-- pre 9 : if ( gprm(11) != 3 ) then { Goto line 11 }
if ( 39 != 3 ) : true.
-- pre 11 : if ( gprm(11) != 4 ) then { Goto line 13 }
if ( 39 != 4 ) : true.
-- pre 13 : if ( gprm(11) != 5 ) then { Goto line 15 }
if ( 39 != 5 ) : true.
-- pre 15 : if ( gprm(11) != 6 ) then { Goto line 17 }
if ( 39 != 6 ) : true.
-- pre 17 : if ( gprm(11) != 7 ) then { Goto line 19 }
if ( 39 != 7 ) : true.
-- pre 19 : if ( gprm(11) != 8 ) then { Goto line 21 }
if ( 39 != 8 ) : true.
-- pre 21 : if ( gprm(11) != 9 ) then { Goto line 23 }
if ( 39 != 9 ) : true.
-- pre 23 : if ( gprm(11) != 10 ) then { Goto line 25 }
if ( 39 != 10 ) : true.
-- pre 25 : if ( gprm(11) != 11 ) then { Goto line 27 }
if ( 39 != 11 ) : true.
-- pre 27 : if ( gprm(11) != 12 ) then { Goto line 29 }
if ( 39 != 12 ) : true.
-- pre 29 : if ( gprm(11) != 13 ) then { Goto line 31 }
if ( 39 != 13 ) : true.
-- pre 31 : if ( gprm(11) != 14 ) then { Goto line 33 }
if ( 39 != 14 ) : true.
-- pre 33 : if ( gprm(11) != 15 ) then { Goto line 35 }
if ( 39 != 15 ) : true.
-- pre 35 : if ( gprm(11) != 16 ) then { Goto line 37 }
if ( 39 != 16 ) : true.
-- pre 37 : if ( gprm(11) != 17 ) then { Goto line 39 }
if ( 39 != 17 ) : true.
-- pre 39 : if ( gprm(11) != 18 ) then { Goto line 41 }
if ( 39 != 18 ) : true.
-- pre 41 : if ( gprm(11) != 19 ) then { Goto line 43 }
if ( 39 != 19 ) : true.
-- pre 43 : if ( gprm(11) != 20 ) then { Goto line 45 }
if ( 39 != 20 ) : true.
-- pre 45 : if ( gprm(11) != 21 ) then { Goto line 47 }
if ( 39 != 21 ) : true.
-- pre 47 : if ( gprm(11) != 22 ) then { Goto line 49 }
if ( 39 != 22 ) : true.
-- pre 49 : if ( gprm(11) != 23 ) then { Goto line 51 }
if ( 39 != 23 ) : true.
-- pre 51 : if ( gprm(11) != 24 ) then { Goto line 53 }
if ( 39 != 24 ) : true.
-- pre 53 : if ( gprm(11) != 25 ) then { Goto line 55 }
if ( 39 != 25 ) : true.
-- pre 55 : if ( gprm(11) != 26 ) then { Goto line 57 }
if ( 39 != 26 ) : true.
-- pre 57 : if ( gprm(11) != 27 ) then { Goto line 59 }
if ( 39 != 27 ) : true.
-- pre 59 : if ( gprm(11) != 28 ) then { Goto line 61 }
if ( 39 != 28 ) : true.
-- pre 61 : if ( gprm(11) != 29 ) then { Goto line 63 }
if ( 39 != 29 ) : true.
-- pre 63 : if ( gprm(11) != 30 ) then { Goto line 65 }
if ( 39 != 30 ) : true.
-- pre 65 : if ( gprm(11) != 31 ) then { Goto line 67 }
if ( 39 != 31 ) : true.
-- pre 67 : if ( gprm(11) != 32 ) then { Goto line 69 }
if ( 39 != 32 ) : true.
-- pre 69 : if ( gprm(11) != 33 ) then { Goto line 71 }
if ( 39 != 33 ) : true.
-- pre 71 : if ( gprm(11) != 34 ) then { Goto line 73 }
if ( 39 != 34 ) : true.
-- pre 73 : if ( gprm(11) != 35 ) then { Goto line 75 }
if ( 39 != 35 ) : true.
-- pre 75 : if ( gprm(11) != 36 ) then { Goto line 77 }
if ( 39 != 36 ) : true.
-- pre 77 : if ( gprm(11) != 37 ) then { Goto line 79 }
if ( 39 != 37 ) : true.
-- pre 79 : if ( gprm(11) != 38 ) then { Goto line 81 }
if ( 39 != 38 ) : true.
-- pre 81 : if ( gprm(11) != 39 ) then { Goto line 83 }
if ( 39 != 39 ) : false.
-- pre 82 : (JumpVTS_PTT) Jump to TTN 1, Chapter 39
-> sprm(4:Title number in volume) = 1 (0x0001)
-> sprm(6:PGC number) = 1 (0x0001)
-> sprm(7:Chapter number (or PGN)) = 39 (0x0027)
-> sprm(14:Video preference and current mode) = 0 (0x0000)
------> Entering VTST 1 , 1 TTN 1 (2:55:46) Title 1
******* Start playback VTST 1 , 1 TTN 1 (2:55:46) Title 1...
******* Playing Program 39, Cell 39 (2:04.06) (Chapter 39)
******* End playback of PGC 1.
-- post 1 : Set gprm(5) =(mov) 1
-- post 2 : Set gprm(1) =(mov) 1
-> gprm(1) = 1 (0x0001)
-- post 3 : Set gprm(0) =(mov) 3
-- post 4 : (CallSS) Call the VMGM PGC 3, resume cell 1
------> Entering VMGM , LU 1 (--) , 3 (dummy)
-- pre 2 : if ( gprm(1) == 1 ) then { Set gprm(0) =(mov) 12 }
if ( 1 == 1 ) : true.
-> gprm(0) = 12 (0x000C)
-- pre 3 : if ( gprm(1) == 1 ) then { LinkPGCN PGC 12 }
------> Entering VMGM , LU 1 (--) , 12 (dummy)
-- pre 1 : if ( gprm(0) > 12 ) then { LinkPGCN PGC 13 }
if ( 12 > 12 ) : false.
-- pre 2 : Set gprm(7) =(mov) 1
-- pre 3 : Set gprm(0) =(mov) 12
-- pre 4 : Set gprm(9) =(mov) 0
-- pre 5 : Set gprm(5) =(mov) 1
-- post 1 : if ( gprm(2) != 1 ) then { Goto line 11 }
if ( 2 != 1 ) : true.
-- post 11 : if ( gprm(2) != 2 ) then { Goto line 21 }
-- post 12 : if ( gprm(3) != 1 ) then { Goto line 21 }
-- post 13 : Set gprm(3) =(mov) 2
-> gprm(3) = 2 (0x0002)
-- post 14 : Set gprm(7) =(mov) 1
-- post 15 : Set gprm(9) =(mov) 0
-- post 16 : Set gprm(5) =(mov) 1
-- post 17 : Set gprm(12) =(mov) 5
-> gprm(12) = 5 (0x0005)
-- post 18 : (SetHL_BTN) Set Highlighted Button =(mov) 1024 (button 1)
-- post 19 : Set gprm(0) =(mov) 11
-> gprm(0) = 11 (0x000B)
-- post 20 : (JumpSS) Jump to VMGM PGC 11
------> Entering VMGM , LU 1 (--) , 11 (dummy)
-- pre 1 : if ( gprm(0) > 11 ) then { LinkPGCN PGC 12 }
if ( 11 > 11 ) : false.
-- pre 2 : if ( gprm(12) == 5 ) then { Set gprm(0) =(mov) 5 }
if ( 5 == 5 ) : true.
-- pre 3 : if ( gprm(12) == 5 ) then { LinkPGCN PGC 5 }
Can anyone give me some advice.
thanks
George W.
Re: Replication problem, who's fault?
on Dec 13, 2006 at 5:04:27 pm
Did the person who Authored the DVD update DVD Workshop 2.x with the DLT Patch issued last year?
http://www.ulead.com/tech/dws/dws_ftp.htm
Out of curiosity, the button that does not work -- would that button take you to an area of the DVD that would be on the 2nd layer (when the project is burned to DL Disc)?
Also, at the 1:24:00 mark, would that be around/near a layer break (again, if it were burned to DVD9)?
Did the images provided to the Replicator pass their verification process (before doing the print run)?
Regards,
George
stoofercat
on Dec 14, 2006 at 9:09:33 am
[George W.] "Did the person who Authored the DVD update DVD Workshop 2.x with the DLT Patch issued last year?
Did the images provided to the Replicator pass their verification process (before doing the print run)?"
I am waiting to find out if they used the DLT update.
yes the button should take you to an area on the second layer
I think the 1:24:00 mark is near the break as the total run time of the DVD is 2:55:00
The DLT was verified after it was recorded by the Authorer
Bill Stephan
on Dec 13, 2006 at 5:25:42 pm
Did the check discs from the replicator exhibit the problems you are complaining about? Or did you not get check discs? It is foolish to proceed with a replication job without obtaining check discs and verifying their correct operation in a number of different DVD players.
That bit of business aside, if the DVD author can burn a good DVD-R of the project, there should be no problem replicating from DLT tapes, provided that the DLTs are good and the authoring software formats the project correctly. To check the DLTs, burn a DVD-R from the data on the DLTs, and check for the problems you are experiencing.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
stoofercat
on Dec 14, 2006 at 9:15:53 am
[Bill Stephan] "Did the check discs from the replicator exhibit the problems you are complaining about? Or did you not get check discs? It is foolish to proceed with a replication job without obtaining check discs and verifying their correct operation in a number of different DVD players.
That bit of business aside, if the DVD author can burn a good DVD-R of the project, there should be no problem replicating from DLT tapes, provided that the DLTs are good and the authoring software formats the project correctly. To check the DLTs, burn a DVD-R from the data on the DLTs, and check for the problems you are experiencing."
I did not get check discs from the replicator.
the problem I have is that the replicators say that if they send me the DLTs it will invalidate any claim I have against their company because I could 'doctor the tapes' they did say that if I give them the address of an independant company that can test the DLTs they will do that but obviously I will have to pay for that if it does turn out to be an authoring problem which is why I am seeking advice on this forum.
Trai Forrester
on Dec 14, 2006 at 9:11:28 am
Hi Stoofercat,
You could have a combination of factors going on with this one. Best to get this project into the hands of a qualified fourth party.
I know someone, if you're interested :-)
Sorry you're having issues with your DVD,
Trai
Trai Forrester - DVD pioneer, consultant
Owner -New Constellation Technologies
Chair - The DVD Producers' Guild (launching soon!)
Principle - TFDVD Research Labs
Co-Creator
- DVDAfterEdit
(divested)
645 Penfield Avenue, Havertown PA (outside Philadelphia) 19083 USA
800-213-2297 - 610-924-9204 - fax: 610-924-0657
stoofercat
on Dec 14, 2006 at 9:20:51 am
[Trai Forrester] "You could have a combination of factors going on with this one. Best to get this project into the hands of a qualified fourth party.
I know someone, if you're interested :-)"
Hi Trai, I know that would be the answer but before we do anything like that I need to be pretty certain it is the replicators fault otherwise it is going to be a very expensive mistake.
Trai Forrester
on Dec 14, 2006 at 9:45:28 am
Very good, Soofercat,
Just know, that at this stage, everyone's in cover their you-know-what mode. Your good author has no way of knowing what was sent in, he didn't really 'verify' the DLT tapes (please see the second page of this article, here); and the replicator just manufactured a DVD that doesn't work, regardless of who's at fault. Ouch.
As far as costs go; you wouldn't happen to be an Indie Film maker would you? If not, then at least you'd soon be limping around and batting one handed, with a working DVD :-)
Take care,
Trai
Co-Creator
- DVDAfterEdit
(divested)
