How to Fix DVD's?
COW Forums : DVD Authoring
larry watts
How to Fix DVD's?
on Dec 4, 2006 at 9:04:59 pm
We author quite a few DVD's. WE duplicate in-house and monthly we send out some for replication.
We have one DVD that must have a problem because many are being returned to us.
It stops playing at a certain point on some players, but not on others.
How do we find out what the problem is and then fix it?
BTW We edit video with Vegas and author with DVD architect.
Larry
LSW
George W.
Re: How to Fix DVD's?
on Dec 4, 2006 at 9:39:15 pm
Which version of DVD Architect are you running?
Is the "Stop" point the same with the bad discs (i.e. at the same time mark), or does the stop point vary from user to user?
Have any users complained that the DVD is not playable at all? NOTE: there is a current issue in all versions of DVD Architect that prevent burned DVD's from playing in some dvd recorder/players (LG DVD Recorder/players is a brand that is often mentioned). Sony is aware of the issue, and has said they will eventually issue a patch for DVDA4 (current DVDA 4a does not include a fix).
Are you burning Single or Double layer discs, and are the problem discs Burned or Replicated?
Regards,
George
larry watts
on Dec 5, 2006 at 6:49:20 pm
We are running DVDA 3.0
It appears that it is stopping at the same point. The DVD's play fine until that spot.
(No one has said it won't play at all) Single Layer
We had some trouble burning the DVD's after production and had to replace some footage where a person turned their head fast. We first used the control room tape and later went to the camera tapes.
Neither seemed to fix the problem, but we eentually got a burned DVD. We are duplicating in-house on
pretty solid duplicators.
It appears that our Sony DVD players can jump over the spot but some cannot. Usually it is the cheaper players.
I'd like to find software that could analyze these before we send them out.
Thanks! Any ideas?
Larry
LSW
George W.
on Dec 6, 2006 at 12:30:51 pm
It's interesting that it stops at the same point for those who have a problem. That could be related to how the disc was authored, or perhaps a bad batch of discs? Does the same problem exist (at the same spot) if you burn to a different brand of disc?
Are you burning your discs at MAX Speeds? How do you burners work -- if they start off burning at a slower speed, then kick in to a faster speed (which alot of burners do), I'm wondering if the point where they are changing speeds might be giving you a problem.
You mentioned in-house duplicators -- I was wondering if the "bad" discs are all coming from one burner in one of your duplicators. Can you track the bad discs to a single burner in one of your duplicators?
You could try downloading the free VS Inspector to san one of the problem discs
http://copytodvd.com/products/inspector/inspector.php
Also, if you know how to use PGCedit (another free tool), you can run it in debug mode to walk through your dvd. It might highlight a problem with one of the VM Commands.
Regards,
George
