Accidently adjusting 16 -235 twice?
COW Forums : DVD Authoring
sharad
on Nov 29, 2006 at 8:50:02 pm
If you prepare video footage in a program like After Effects and apply a levels adjustment to go from 0-255 to 16-235, do you have to then compensate when using an mpeg encoder such as Cinema Craft Encoder? Encoders are usually automatically set to 16-235 range when using a preset for NTSC DVD. Would this erroneously further narrow the level range if you had already prepared the master footage within those specs?
Frippy
Re: Accidently adjusting 16 -235 twice?
on Nov 30, 2006 at 12:56:17 pm
if you use CCE or ProCoder you NEED to set 16..235 because any composition/editing software makes it better - no need use CCEs or CPC2 16..235 or ShinkColorSpace...
If you use mainConcept encoder (Adobe Premiere, etc) - then you not need to set levels because encoder automatically set it.
sharad
on Nov 30, 2006 at 5:02:34 pm
I'm not 100% sure how to interpret the first sentence of your answer. I believe you are advising that it is better to shrink the colorspace and limit the levels in the master footage creation rather then during the encoding. Keep it 1-255 in the encoder if the master footage is already 16-235.
nostalgia is like heroin
