Doing a NTSC DVD in PALand. What ir IRE black level?
COW Forums : DVD Authoring
Peter Corbett
on Nov 29, 2006 at 9:35:20 am
I posted this on the edit forum without response. I've just had a PAL master converted to NTSC DVCPRO50 for authoring a NTSC DVD.
The transfer was great but I notice the picture is a little "bright". Is this 7.5 blahdyblah NTSC black level thing. When I crush the blacks it looks fine. Do I have to do any adjustments to the black level on the encode to NTSC MPEG-2. or does it auto correct when playing on a DVD player in the States?
Cheers,
Peter
Peter Corbett
Powerhouse Productions
Australia
http://www.php.com.au
eric
Re: Doing a NTSC DVD in PALand. What ir IRE black level?
by
on Nov 29, 2006 at 7:32:29 pm
You'll need to adjust blacks before your encode. Do you have a waveform? Is this on a DVCPRO50 Tape?
Peter Corbett
on Nov 29, 2006 at 10:16:46 pm
Thanks Eric,
Yes it's on NTSC DVCPRO50 tape. I do have a tubed waveform monitor, but I'm not reall expert with it. I usually use to make sure my video levels SP don't go illegal. Should I crush the blacks as I digitize?
Peter
Peter Corbett
Australia
eric
by
on Nov 29, 2006 at 10:55:14 pm
I'd say yes..if you don't have a scop[e then go with what looks good to yours/client's eye.
