Bitwise DVD authoring
COW Forums : DVD Authoring
Benn Gunn
on Oct 23, 2006 at 11:26:12 am
I want to get to grips with using bitwise authoring and I wondered if anyone has any recommendations on any websites or books I should look at for my research? I've done a few websearches and havent managed to find anything which will help me out in the way I'd like.
Cheers
Frippy
Re: Bitwise DVD authoring
on Oct 23, 2006 at 4:52:19 pm
What do you need to create?
Example....?
Benn Gunn
on Oct 26, 2006 at 12:17:48 pm
I'm looking at programmable playlists for music titles....kind of like a jukebox for up to 30 tracks. I want to be able to make a selection of tracks which is stored, then play the songs in order. I also would like to be able to erase all the selected tracks from the list so I can start fresh, and to be able to remove th elast selected track from the sequence without affecting the rest of the selection.
I'm not searching for a total solution on this forum, just some recommendations for refernece points.
Cheers
Frippy
on Oct 26, 2006 at 12:59:24 pm
Ok
First solution: sonic scenarist. you can create ANY YOU WANT. But - if you know how to programming
Second solution: try to use sonic's Roxio Easy media creator:
see http://www.roxio.com/enu/products/creator/suite/overview.html
and http://www.roxio.com/enu/products/creator/suite/features.html
My solution - create DVD from Roxio, then decompile by DVDReauthor, then author as you want in Scenarist :)
eric
by
on Oct 27, 2006 at 11:55:49 pm
http://discussions.apple.com/thread.jspa?messageID=1998386�
This is a thread from Apple's site - check out Hal Maclean's jukebox script - its DVDSP but it might give some insight
http://www.dvd-replica.com/
This is great site - not sure if they have any scripting examples
http://www.amazon.com/DVD-Authoring-Production-Ralph-Labarge/dp/1578200822/...
Lastly check out this book
Not to much info on-line on Bit shifting but you'll get the hang of it
