Looking 4 Software Recommendation
COW Forums : DVD Authoring
ohio5258
on Oct 9, 2006 at 7:30:57 pm
Hello All, I need a software recommendation.....I need to create an educational DVD using still Pics and Text. Please recommend the best software for this creation....Thanks In Advance. JA.
Pierre-Luc
Re: Looking 4 Software Recommendation
on Oct 9, 2006 at 11:32:44 pm
It depends of your authoring knowledge, how familiar are you with authoring DVD or any other programming software ?
ohio5258
on Oct 10, 2006 at 8:54:05 am
I am very capable. I am just looking for a software recommendation in order to save time. I am lookin to author a DVD for my business using still pics and text only. Can anyone please recommend the best software for this type of production. Thank You in Advance. JG.
eric
by
on Oct 10, 2006 at 5:43:45 pm
There is no "best". But like Pierre said it depends on your knowledge of DVD authoring in general. Try them out - see which one is best for you
Encore
DVDit
DVDLab
Vegas
Frippy
on Oct 15, 2006 at 7:09:19 am
The best choise for you is DVD Maestro by SPRUCE tech.
By DVDMaestro you can grag/drop stills, create buttons, and simply create navigation link
If you a expert in dvd authroing - Sonic Scenarist.
All you need - Scenarist can do!
eric
by
on Oct 15, 2006 at 8:57:25 pm
Why would Meastro be the best choice? Let's not send the guy in some crazy direction. I don't think he's intrested in spending hundreds/thousands of dollars on some sencond hand authoring system which isn't supported anymore...not to mention the price of the Scenarist :):)
Frippy
on Oct 17, 2006 at 2:20:40 pm
for static images + sounds with automatic commands for menus - maestro is best chice...
cost - hm... :)
your recomends:
- Encore
my test: encore crash after >400 still images, all versions
- DVDit
problem by problem...
- DVDLab
can't work with still images correctly
ps: scenarist BEST, but mooore programming requred.
pps: i am use scenarist for all my projects, but for dummy menus/sound i use dvdmaestro
eric
by
on Oct 17, 2006 at 7:32:31 pm
Frippy
" maestro is best chice...
cost - hm... :) "
What does this mean? The best price on a Meastro system I've seen was around $1500.00...The Scenarist? Around $6000.00
Now since he was asking a such a simple authoring question I would have to assume he wasn't instrested in spending thousands of dollars....right? I'm sure you know what I'm talking about since you obviously have spent several thousand dollars for your gear :)
Or...have you confused this site with http://www.videohelp.com ??
All Fun & Games :):)
Eric
Frippy
on Oct 18, 2006 at 5:23:47 am
I perfectly understand you.
But in Encore it will be extremely to make that the author asks.
In DVDLab - it is impossible.
Probably it is better way to buy once a program, and do in it all.
O! Where is author????
How he author project?
ohio5258
on Oct 19, 2006 at 4:00:19 pm
WOW.....Thanks for all the info......probably will go with the lowest cost. Thanks for the Input. JG.
