anyone use roxio toast ?
COW Forums : DVD Authoring
arty
by
on Aug 31, 2006 at 11:20:58 am
everytime i try to burn a disc it is coming out 16x9
i can't find anyway to fix this.
i'm using a fcp quicktime file to make the burn...but i do this all the time !
Borjis
Re: anyone use roxio toast ?
on Aug 31, 2006 at 9:49:18 pm
I use it to burn the video_ts folder but I wouldn't rely on it
for creating a dvd from video.
David Roth Weiss
on Sep 1, 2006 at 5:55:07 am
Actually, Toast is great for making DVDs from video sources -- that is, if you don't happen to mind that only about 40% of the people you send them to will be able to play them. Okay, maybe the DVDs aren't quite that incompatible, but I assure you, the discs encoded and then burned using Toast simply cannot be relied upon. You can quote me, and if Roxio wants to sue me... bring it on.
DRW
Arty
by
on Sep 1, 2006 at 1:26:58 pm
well so far i haven't had any major problems...
i usually use toast for quick dailies to my clients or smaller shorts...
i use dvdsp for the bigger things
the problem is....
everytime i make a dvd it is coming out 16x9...and i can't figure it out !
and i can't seem to get in touch with roxio...
