SP AUTHORING with 4.1
COW Forums : DVD Authoring
John O'Brien
on Aug 17, 2006 at 7:14:52 pm
Have just completed burning a couple of test discs using both quicktime and mp2 files (produced by Squeeze4/1). The squeeze files look much better just FYI. Do you think upgrading to something like digigami would make another incremental improvement over the sorenson version?
also- I continue to have some set top compatibility issues with an old Phillips and newer Sanyo player. Discs play fine in a inexpensive Memorex. I think the following warnings produced during the burn by SP might have something to do with this:
Warning: The file
eric
Re: SP AUTHORING with 4.1
by
on Aug 17, 2006 at 8:23:27 pm
These are just warning DVDSP gives when doing a build. Just cuirius - Whats in track 1 of your project. Im kinda confused why it saying its not going to inluse those VOB files in your final buuild?
John O'Brien
on Aug 17, 2006 at 9:42:03 pm
ah....that's it! I created a button but ended up losiing track of it while learning the graphics overlays etc....that's why I got those warnings. Don't suppose it could account for the decrease in compatibility (sanyo set top) do you?
J.
eric
by
on Aug 17, 2006 at 9:49:30 pm
No...But what is your bitrate? Did you use AC3 Audio in your title? These are the two most common factors that effect compatibilty
John O'Brien
on Aug 17, 2006 at 9:53:39 pm
I boosted the bitrate to 7.1 (I think ) and used an MP3 file in the title loop.
thanks for your help here.
J.
eric
by
on Aug 17, 2006 at 10:07:54 pm
It all depends on the length of your titles but under 7mb/s is always smart. Get rid of that Mp3 file for sure and transcode it to AC3
