DVD-Lab PRO 2.0 Released
COW Forums : DVD Authoring
George W.
on Jul 27, 2006 at 10:56:50 am
DVD-Lab PRO 2.0 has been released!
I believe the list of features, combined with a clean interface and extremely low/reasonable price, makes the "PRO" version one of the most advanced SD DVD Authoring packages for the PC.
A comparison chart for the different levels of DVDLab:
Here are some of the new features in DVD-Lab PRO 2.0
- More compatible slideshow - in full GOP instead of I-frame
- Mega-Project with disk caching - this will cache data during designing into disk which will allow user to create project with huge amount of menus without windows crying for memory. With Mega-Project you can now create up to 640 menus per VTS!
- Each menu can have up to 30 cells inside where each cell can have its own set of buttons and other parameters.
- Smart Compile will recompile only the changed menu parts and keep the video vobs from previous compile. This way you can recompile menu changes within a minute!
- Multi-PGC title. The Segment Title has been now redone to a full Multi-PGC title. (Each segment in a Multi-PGC Title can now have its own pre and post commands)
- Audio Title can show new slide on each mark
- Pre and Post verificaton log
- Multiple Angles
- Buttons on Movies (Each chapter can have different buttons)
- Faster transition encoding
- native 24p support (Note: this is not 23.97 with pulldown)
- Simpler to use and more robust audio transcoder - can transcode any audo file for which you have codec
- Subviews in Conections - place certain project objects to a freely definable subview (up to 9 subviews) so you can work with them separate from the main
© 2018 All Rights Reserved
