Overscan lines and Encoding using Apple Compressor
COW Forums : DVD Authoring
Nick
by
on Jul 9, 2006 at 12:54:58 am
My 35mm transferred to a 16:9 QT file has some noise running down the left side (maybe part of the audio track or something) -- it only appears on the monitor, but not on the TV. Also, I've been reading on the net about "overscan lines" - apparently there's one at the very bottom of the frame, which I'm supposed to crop before encoding.
Should I somehow be cropping these areas (on the sides and the bottom) before encoding to increase the effectiveness of the encode? If I am, what do I keep in mind given I'm working with 16:9 video?
I'm encoding using Apple's Compressor -- setting a bunch of compression markers in FCP to ensure the encode is effective -- and I'm happy with the results so far. Just wanting to see if I working on dealing with the overscan areas will get me more efficiencies.
Any ideas/thoughts on what to do about the overscan lines for encoding?
Nikhil
http://www.indiancowboy.com
Noah Kadner
Re: Overscan lines and Encoding using Apple Compressor
on Jul 9, 2006 at 1:58:21 am
I would not crop because you'll be decreasing quality. But if you want to matte in a border on the sides to cover the area that would preserve the quality while covering up the junk just in case someone is watching on a computer rather than their computer.
Noah
