problems
COW Forums : DVD Authoring
kerry
problems
on Jun 6, 2006 at 3:44:11 pm
hi i managed to convert an avi video file using a trial version of Gear Video 8.1 and have now burnt it onto dvd+rw. it plays well on a PC and also a Mac. however it won't play properly on the dvd player thats with the TV.- it stutters and stops and starts. i need it to play on all three. please help.
Noah Kadner
Re: problems
on Jun 6, 2006 at 4:08:52 pm
Is gear an authoring program or just video conversion? To make a DVD player compatible disc you need to author. For the PC- Adobe Encore or Sonic DVDit would do the trick.
Noah
Mike_S
Re: problems
on Jun 8, 2006 at 11:35:21 am
Gear Video will allow for DVD authoring, Mpeg 2 encoding - what's needed to make a DVD
Stuttering playback on a DVD player suggests maybe the data rate of your mpeg2 video is too high - did you keep it down below 8Mb/sec? If you left the sound in PCM format, that can eat data rate ...
http://www.gearsoftware.com/support/documentation/encode-video-dvd.cfm might help.
