DVD playback stops/ gets stuck arbitrarily...
COW Forums : DVD Authoring
on May 25, 2006 at 4:01:08 pm
Hi All,
When I try playing back my DVD either on my Apple G4 Powerbook or a DVD Player, I find that the DVD gets stuck at a certain point, and the only way is to continue, is to remove it from the system, then try using the Scene Index to get in at a different point. No 2 DVD's stop at the same place.
I made this DVD from a 1Hr 51Min film, on a Dual Layer Verbatim DVD+R disk on my G5, using DVD Studio Pro. I created the Mpeg-2using Sorenson Squeeze Version 4.3, and used Stereo Audio compressed to AC-3.
Since this was a feature, I had 6 Reels - each with its own Video and Audio that I imported into DVD SP.
In Sorenson Squeeze, I used a bit rate of 6.5Mbps and 2Pass VBR. I used 23.98 Fps (since the DVD standard says, palyers will accept it, and add pulldown on playback?).
Any help would be greatly appreciated. Thanks in advance for your replies.
© 2018 All Rights Reserved
