DVD Durability Issues
COW Forums : DVD Authoring
on May 12, 2006 at 10:43:43 am
Got a major problem.
I make short films for local elementary schools and put them on DVD's. Lately, the DVD's have been giving me issues. While playing them DVD's on the players (Samsungs and Sanyos), they play well the first few times. However, after awhile, they begin to skip and eventually become unreadeable.
My setup:
DVD Architect 3
HP DVD Burner
Mermorex DVDs
Furthermore, DVDs that I play a lot during short time periods (3 seperate times in 30 minutes) are the ones that become undreadable more so than long time periods (3 seperate times in 3 months).
Thanks you for any help.
George W.
Re: DVD Durability Issues
on May 12, 2006 at 11:45:26 am
This could be a number of different things...
-the quality of the media (try a different brand - genuine Tayo Yuden has gotten good reviews)
-the quality of the burn (don't burn at the highest burn speed -- try 4x or lower)
-the burner -- check if there's a burner firmware update available (follow instructions when updating firmware)
-the quality of the burning software -- I use DVDDecryptor to burn -- so far it's been great (they updated the burning engine as a separate burning tool since Decryptor is no longer updated))...
-the handling of the discs (don't touch the surface, handle by outer edges)
-whether or not you put a sticky label on the disc (you should not)
on May 12, 2006 at 1:22:43 pm
Try Ritek or TDK discs. I've never used memorex DVDs before, although I have used their audio tape products with no problems in the past.
© 2018 All Rights Reserved
