DVD DL on a G5 dual 1.8
COW Forums : DVD Authoring
orwa
by
on May 10, 2006 at 6:59:05 am
Hello all,
we work on DVD SP4, we did build a DVD9 project with an automatic break point (seamless), then put it on two DVD5s, took it to a PC and tried to burn the DVD9 using nero software & easyDVD ...
it worked once... then all of the DVDs end up with the lowest compatibility I could imagine...! doersn't work on most players & even PCs...
What is the best workflow you'd suggest in our case? we are about to upgrade our system to do all of this normally... but before we do, we have some urgent jobs at stake!
eric
Re: DVD DL on a G5 dual 1.8
by
on May 10, 2006 at 4:59:35 pm
DL burning tends to be a pain sometimes. First off you need that break point to be non-seamless (see manual). Also burn the disc straight out of DVDSP. third party buning apps tend to chose thier own layer break which might cause problems.
