DVD Cover & Insert Size For Standard Box
COW Forums : DVD Authoring
guaiaciar
on Apr 30, 2006 at 1:11:17 am
Can someone tell me the size and other specifications for a DVD cover spanning both the front and back of a standard DVD box and the specifications for an insert going in there? Or where can I find this information? Thank you.
Alex Alexzander
Re: DVD Cover & Insert Size For Standard Box
on Apr 30, 2006 at 4:15:59 am
For the cover, it depends on the case used. The most common case out there is a standard 14mm Amaray type case. There are several others, such as a 7mm, and 10mm thin-pack from Nexpack. NexPack makes the standard 14mm black Amaray case you most likely see. There are also Double-Alpha and even triple-Alpha.
So for the standard Amaray, 14mm, which is what most Heino type automation would run, it would be the following:
From left to right, fully extended: 10
David Roth Weiss
on Apr 30, 2006 at 4:59:18 pm
There are templates all over the Internet at almost every DVD related website. Just Google "DVD sleeve template" and you will get templates for all the major graphic design programs including PhotoShop, Quark, etc.
Jim O'Shea
on May 5, 2006 at 2:46:51 am
You can find templates for both the cover (commonly called wraps) and the inserts (the postcard, or booklet inside the case) here: http://www.pacificdisc.com/PrepArtworkRep.html
Good luck
Jim
