Bitrate Questions
COW Forums : DVD Authoring
Steven Free
Bitrate Questions
on Apr 12, 2006 at 2:39:48 am
Hello,
I'm all finished with 2 different video projects in Premiere 6.5 and ready to export them both from Premiere using the "Adobe MPEG Encoder" and bring them into a DVD authoring program called "DVD Lab Studio" by Mediachance. I will be burning a master of each to have DVD replications made down the road.
My question is how do I know what my audio bitrate should be set to http://www.videohelp.com/calc.htm so I can have a Calculated Bitrate?
Also, what is the difference between "Calculated Bitrate" and "DVD Max Bitrate" on that site?
Thank you
Noah Kadner
Re: Bitrate Questions
on Apr 12, 2006 at 3:28:55 am
If you are using VBR, you set avg to calculated and max to max. For Ac3, typically 192Kbps is fine for stereo.
Noah
George W.
on Apr 12, 2006 at 11:29:49 am
In that calculator you referenced, the item labeled "DVD Max Bitrate" is just a reference for how large your MAX video bitrate can be based on the dvd spec limit of 9800kbps (video+audio -- 10080kbps adding in subpics). Notice how it changes when you adjust the audio bitrate (it leaves a little room for menus and overhead). But I wouldn't necessarily use it for VBR MAX because you might be setting the video bitrate up to 9600kbps (and some encoders will periodically "spike" above your stated max number -- potentially making your dvd non compliant).
Also, if you plan to have a second audio track, make sure you change the number of audio tracks using the "Advanced" mode of that calculator.
Regards,
George
Steven Free
on Apr 13, 2006 at 8:34:10 pm
I'll give it a try. Thanks!
