high frame rate = lost of synchro
COW Forums : DVD Authoring
macmauro
on Apr 9, 2006 at 9:06:19 pm
hi; i edited a video where images are very fast - still images that sometimes appears at speedness of 1 every 2 frames-
i compressed the video with Compressor; trying different compression and variable bit rates;
the result is that suddenly the synchro between audio and video is lost
the music is faster than; also if at the end of the video every thing return fine.
what could i do to avoid this?
thanks
M.
daniel_l
Re: high frame rate = lost of synchro
on Apr 11, 2006 at 11:17:33 am
What are your compression settings?
Video AllSorts
macmauro
on Apr 12, 2006 at 7:13:35 pm
hi
i used all the kind of standard compression available in compressor
all pal anyway
but the problem was always there
60 minutes HQ, 90 min 120 min and so on...
i tried to made a dvd of the same video using a dvd recorder (yamaha drx1)
at high quality too and the result was very fine
but in this case i can't insert a menu as i do using dvd studio pro
any suggestion?
thanks
M.
