Availability Flag for Subtitles and Audio Streams
COW Forums : DVD Authoring
Michael Lazar
on Mar 4, 2006 at 11:23:39 pm
Greetings!
I'm looking to contact someone who's authored a commercial (replicated) title that used the Availability flag feature of Scenarist to restrict viewer access to subtitle and/or audio streams in a VTS. Please write to me off-list: laz@okeanos.com.
Michael Lazar
eric
Re: Availability Flag for Subtitles and Audio Streams
by
on Mar 5, 2006 at 5:17:06 am
Since this is a discussions forum I think it might be right to ask your question first. If you need private support call Sonic - you paid 10s of thousands of dollars for your authoring system - I know there support sucks but give it a try.
Noah Kadner
on Mar 5, 2006 at 6:29:34 pm
Exactly- we are not tech support that way. If you ask an actual question it's a lot more likely it will be answered.
Noah
Michael Lazar
on Mar 5, 2006 at 8:51:50 pm
Sure. No problem.
First, I don't own a Scenrist system and I'm not looking for technical support.
I am investigating a relatively obscure feature of the DVD Video specifiction know as the Availability flag. This allows the DVD author to restrict access to subtitles and/or audio streams in a given VTS on a per-title (PGC) basis. So, for example, a VTS can be created with four different subtitle streams but the Availability flag can - in theory - be used so that one Title (PGC) provides access to just the first two streams and another Title (PGC) provides access just to the last two streams. By "providing access" I am specifically referring to the use of the subtitle button on the remote. There's a similar flag associated with audio streams as well.
[NOTE: One can use UOPs to completely disable access to subtitle and audio streams in a Title (PGC) but the Availability flag - in theory - provides a finer grained control.]
To the best of my knowledge, Scenarist is the only non-proprietary authoring system that exposes the Availability flag.
Now, back to my question: I'm looking to contact someone who's authored a commercial (replicated) title that used the Availability flag feature of Scenarist to restrict viewer access to subtitle and/or audio streams in a VTS.
Michael Lazar
eric
by
on Mar 5, 2006 at 9:16:09 pm
Yes its an obscure. I could probably answer your question if I knew what it was? :) :)
Michael Lazar
on Mar 5, 2006 at 9:26:00 pm
The specific question regards player behavior when there are "gaps" in the list of available streams.
For example, if the VTS has four subtitle streams (0, 1, 2, & 3) and you only mark streams 0 and 2 as Available in a Title (PGC), do all the players you test behave in a useful and consistent manner when playing this Title (PGC)? Or, are the results undefined with different players behaving differently?
Michael
eric
by
on Mar 5, 2006 at 9:41:56 pm
I have no idea....Sorry
Just Kidding :) From what Ive gathered this feature is not required by manufacturers of set top players. Better players will play the disc fine but some cheapos will faulter. But I must admit Ive never had a reason to use this feature....How do you want your disc to function exactly?
