HD-DVD with 60 frame per second in MPEG-2
COW Forums : DVD Authoring
kinthy
on Feb 6, 2006 at 7:44:37 am
hi all,
try to export a MPEG-2 with FCP with compressor, there have no choice of 60 fps for HD-DVD, it only limited to 30fps.
Is it the standard of HD-DVD have 60fps? If yes, can FCP with compressor can export that kind of file?
Please give advice, thanks.
kinthy
Borjis
Re: HD-DVD with 60 frame per second in MPEG-2
on Feb 6, 2006 at 5:10:01 pm
I don't think you can do an HD-DVD at 60fps. Just 30 or 24 with drop or non-drop.
If your video is indeed 60fps, try dropping it in a 29.97 or 30fps
timeline then render that out.
kinthy
on Feb 7, 2006 at 1:54:12 am
hi all,
Is it HD-DVD /w 60 fps is not a standard?
any solution can produce the HD-DVD /w 60 fps 1080?
please give advice, thanks.
Borjis
on Feb 7, 2006 at 4:54:47 pm
No its not a standard.
It follows the same specs as blu-ray for defined content paramaters.
no 60fps.
convert your 60fps video to 30.
