is one better than the other?
COW Forums : DVD Authoring
coach
on Jan 17, 2006 at 2:11:03 pm
Hello,
Does it matter when burning dvd's if after you have edited it and completed it through compressor if you used dvd SP on each disc burn or is it better or the same if you burn a master copy one time and then create a dvd disc image (.dmg) and then burn copies of your disc that way. It would seem they would both be fine. I am looking for insight into if there are any differences, time...etc...
Coach
Noah Kadner
Re: is one better than the other?
on Jan 17, 2006 at 5:26:13 pm
I prefer to burn multi copies in Toast but quality wise it doesn't matter.
Noah
