Authoring for Denmark
COW Forums : DVD Authoring
Dane Silzle
on Dec 20, 2005 at 8:49:45 pm
I have producted a DVD here in the US and my customer has a division in Denmark whom they sent a copy to.
The Denmark office cannot read/play the dvd how can I fix this ?
Is it a issue of internation code and can I do this with DVDSP 4 ?
All footage was shot and edited in NTSC then compress to MPEG 2 for athoring.
Please help :)
Dane
drp
http://www.drppost.com
Noah Kadner
Re: Authoring for Denmark
on Dec 21, 2005 at 12:21:22 am
What standard is Denmark on? If they're on PAL they can play your disc as long as the region code is set for all regions or Europe. Manual gives great details on this.
Noah
Dane Silzle
on Dec 22, 2005 at 2:56:17 am
Thank you,
I think I have found a fix
In this case my footage is NTSC, I am converting to PAL in Compressor as my customer is able to start the DVD (assuming that this makes it not a Country code issue) but it is playing slow and erratic ( these are NTSC PAL issues, I think...maybe) and although most europe DVD players can switch to play "as is" I can't gaurentee my customer has a multiformat TV or monitor............There-for, I am converting and building a DVD with PAL MPEG 2's and making sure I have at-least 1 & 2 Country code (although DVDSP 4 defult setup is "all" Country code) set.
Thank you again for your response.
Best Regards
Dane
drp
