Question About HD compression for dvd
COW Forums : DVD Authoring
Q_yes just the letter
on Dec 7, 2005 at 2:13:26 am
I have an FCP timeline that is DVCPROHD10860i. I need to export the footage to standard ef so it can be put on DVD. I was going to just export it using the same codec and bring it into after effects and just shrink it down ( i need it to be letterboxed) and then from there use that to compress on dvd. Well, I tried it and it looks like crap. My footage has motion and it becomes pixelated. HELP PLEASE!!! What should I do to get letterboxed footage of good quaity? Thanx in advance for your replies.
David Roth Weiss
Re: Question About HD compression for dvd
on Dec 8, 2005 at 6:35:39 am
Dear Q,
Your thinking is a bit off on this, and you're doing way too many steps. All you need to do is encode using one of the DVD presets in Compressor, making sure to check the anamorphic 16x9 box. This will yeild a DVD that will play 16x9 full screen on a 16x9 TV, and letterboxed 16x9 on a 4x3 TV.
Good luck,
DRW
