DVD for PAL
COW Forums : DVD Authoring
cvbunz
DVD for PAL
on Nov 11, 2005 at 1:35:21 am
I'm creating a Quick Time Movie in Final Cut Pro to be put on DVD for PAL in Europe. What size, compression, frame-rate, etc. do I need to save my QT in Final Cut Pro to get the best results?
daniel_l
Re: DVD for PAL
on Nov 11, 2005 at 11:35:28 am
You need to use Apple's Compressor or DVD studio pro or iDVD rather than Quicktime to get the best results. Simply choose one of the DVD PAL presets depending on the length of your piece.
FYI, PAL MPEG-2 is 720x576 at 25 fps, data rate between 1.5mbps and 8mbps. Audio: either PCM or AC-3
