Application to check format of DVD (NTSC or PAL)
COW Forums : DVD Authoring
Chris Huggett
on Nov 11, 2005 at 12:20:39 am
hey guys
im after an application that can read a DVD that someone has made to see if its an NTSC disc or a PAL disc
Does anyone know of such a thing?
thanks
chris
eric
Re: Application to check format of DVD (NTSC or PAL)
by
on Nov 11, 2005 at 12:29:36 am
http://www.mydvdedit.com/ its a MAC tool though
Check here to see if anything might be of help:
http://www.videohelp.com/tools?s=15#15
Chris Huggett
on Nov 11, 2005 at 2:27:18 am
Hi Eric
i have just downloaded it and put my DVD in, but don't know how to interpret it.
I went to a IFO screen (i think) and it showed a reolution of NTSC 720*540. But it also allowed me to change that to the PAL format. So i was a bit unsure if this was a setting or info about the disc.
Cheers
Chris
eric
by
on Nov 11, 2005 at 5:52:22 am
Its reading the info from the TS folder. It if says NTSC, it certainly is.
eric
by
on Nov 11, 2005 at 6:04:49 am
Wait...720x540? That seams kinda odd. Another thing to try just to make sure is MPEGStream Clip:
http://www.videohelp.com/tools?tool=MPEG_StreamClip
Select any VOB then under "FILE" select get stream info and see what it says
