DVD Studio Pro - Video Bitrate Too High
COW Forums : DVD Authoring
micah et
on Oct 27, 2005 at 2:22:43 am
When i attempt to burn a dvd with DVD Studio Pro, it says that the video bitrate is too high. Do you know how to solve this?
Cheers.
eric
Re: DVD Studio Pro - Video Bitrate Too High
by
on Oct 27, 2005 at 3:59:40 am
lower your bitrate!! :) try to keep your bitrate below 6.5 with AC3 audio. Good luck
micah et
on Oct 29, 2005 at 1:05:03 am
this may sound stupid, but how do you reduce the bitrate. Is it in my export settings from final cut, or in the dvd authoring program?
micah et
on Oct 29, 2005 at 1:05:04 am
eric
by
on Oct 29, 2005 at 2:17:44 am
When you export from final cut do it through compressor.
micah et
on Oct 29, 2005 at 2:20:57 pm
Thanks for the feedback eric, perhaps you have one more little trick up your sleeve.
I have exported the video as an mpeg2 using compressor to keep as much quality as possible, but when attempt to import it into DVD Studio Pro it says it is not a file formate that is supported. Any suggestions greatly appreciated.
cheers.
eric
by
on Oct 29, 2005 at 7:02:10 pm
mmmm...your doing something wrong. All I can say is read the manual carefully. If your new to authoring it takes some time to learn the ins and outs.
micah et
on Oct 30, 2005 at 3:40:03 am
yeah, that is what i did!
in final cut >export>using compressor
eric
by
on Oct 30, 2005 at 5:08:20 pm
When compressor comes up you need to set your bit rate then use AC3 audio to import into DVDSP
