Burn DVDs for both MAC & PC
COW Forums : DVD Authoring
Paolo
on Sep 22, 2005 at 5:24:36 pm
I need to create a DVD compatible on both systems.
I can compile it on PC (using DVDit Pro), and then?
Should I burn it on a Mac or I need to compile it also on Mac?
I tried to burn on PC but it won't be read on Mac.
Any suggestion?
Paolo
martin rose
Re: Burn DVDs for both MAC & PC
on Sep 22, 2005 at 9:12:13 pm
Are you using dvd-r some older macs dont like dvdplusR
Paolo
on Sep 22, 2005 at 9:53:40 pm
I'm using DVD-R burned with Nero as DVD-Video.
David Roth Weiss
on Sep 23, 2005 at 1:30:36 am
Paulo,
The problem may well be with DVDit Pro, because I use Nero and ReelDVD on the PC, and I can play DVDs just fine on my MAC G5.
DRW
Paolo
on Sep 24, 2005 at 1:12:49 pm
Do you burn as ISO/UDF, UDF or DVD-Video.
Paolo
ed
by
on Sep 24, 2005 at 4:33:46 pm
I use DVD SP to build my projects, then drag the Audio & Video_TS folders into Toast and burn it as UDF (DVD-ROM)
for cross-platform compatibility.
HTH,
Ed
David Roth Weiss
on Sep 24, 2005 at 4:34:10 pm
I always burn using the DVD video choice.
ed
by
on Sep 24, 2005 at 4:49:46 pm
I'm using Toast 6.05, (I think the latest version has a new Video_TS files to DVD-Video setting, or something to that effect).
The recommended way to do it in 6.05 is to use DVD-ROM (UDF), drag the Audio & Video TS folders (but take out the .lay, or any layout files, as well as any data files first, they could interfere with playback on some players), and burn at 1x.
Ed
[David Roth Weiss] "I always burn using the DVD video choice."
David Roth Weiss
on Sep 24, 2005 at 5:11:14 pm
Ed,
Paolo started this thread and he's using Nero, not Toast, just as I am. So, your settings in Toast won't really help him. Let's try to compare apples to apples and oranges to oranges...
DRW
ed
by
on Sep 24, 2005 at 6:06:58 pm
Yeah, I know David. Didn't mean to confuse the issue. Nobody responded to his ISO/UDF question for a couple of days, so I tried to help specifically with the ISO/UDF answer. Glad you chimed in
with the actual Nero answer.
Ed
[David Roth Weiss] "Ed,
Paolo
on Sep 26, 2005 at 12:36:55 pm
Yes, I think actually the problem is:
do I need to burn as UDF or ISO/UDF?
I tried as UDF but I had some problem on DVD players...
thanks a lot,
Paolo
Mike Cohen
on Sep 26, 2005 at 2:07:19 pm
I always burn an ISO using Nero.
I am using Adobe Encore, which spits out an IMG file when it makes a DVD image.
I change the extension from .img to .iso, and burn with Nero to DVD-R.
My particular drive and Nero don't let me burn slower than 4x using the particular Discmakers DVD-R media, but the results are 95% good, a few coasters.
The only problems I have is Windows Media Player has trouble with the discs, even duplicated ones. But Microsoft causes a lot of problems, so that's no surprise is it?
Mike
Avant Guarde
Burn DVDs that work on both MAC & PC
on Oct 27, 2005 at 4:58:51 pm
i am using dvd studio pro and i burned a dvd but when i put it in my pc it opens as a data file, any advice ya'll?
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." -Antoine de Saint-Exupery
