PCM Audio in Mono. Why?
COW Forums : DVD Authoring
Kara jensen
on Sep 7, 2005 at 12:23:14 am
Hi I am exporting a video and wav file from Avid as a quicktime file into sorenson squeeze then squeezing the video and putting it in to Reel DVD. The problem is for some reason the pcm audio file is mono. I have been burning tons of DVD's and this hasn't been an issue but all the sudden, mono. Not sure what setting somewhere is messed up. Any ideas? Thanks,
Kara Jensen
Expectations Video Productions
Borjis
Re: PCM Audio in Mono. Why?
on Sep 7, 2005 at 5:44:16 pm
Either Avid output or possibly squeeze is doing.
check your export settings on both.
Kara jensen
on Sep 7, 2005 at 7:10:41 pm
It is definetly coming from the conversion from avid to quicktime file because when I check properties of the audio file associated with the export it says mono. Go figure. I have the audio in the timeline set at mid so it is stereo and I have checked the settings a million times and they look right...
Kara Jensen
Borjis
on Sep 7, 2005 at 7:42:58 pm
so Avid audio export is definitely stereo but creating a mono
track?
What version of quicktime are you running? That might be part
of the problem.
Bill Stephan
on Sep 8, 2005 at 9:32:05 pm
Is the Audio Mix Tool in Avid set to "Mono Mix"? You must be on "Stereo Mix" if you want to export stereo regardless of how the tracks are built in the timeline.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
