DVD sp3 wont open
COW Forums : DVD Authoring
criis daw
DVD sp3 wont open
on Sep 1, 2005 at 2:16:01 pm
Anybody got any idea why my copy of DVD studio pro 3 wont open , or rather quits when i open a project or try to import an asset into a new project. I haven't used it for some monthes and in the meantime the only difference is that i have installed the latest mac (10.4) OS on my computer. ??
Any ideas or advice on where to get help very much appreciated.
chris
daniel_l
Re: DVD sp3 wont open
on Sep 2, 2005 at 10:06:56 am
1st thing to try is to run a System update (under the Apple Menu - Obviously you'll need an internet connection)
2nd is to ditch the .plist preferences file and re-launch DVDSP
3rd is to trash & re-install the Application.
If all that fails try posting your problem to the Apple DVD studio Pro forum:
http://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=155
criis daw
on Sep 2, 2005 at 1:41:12 pm
Thanks for the advice, I will try it as soon as i am back at the studio
cheers..
chris
criis daw
on Sep 5, 2005 at 1:57:35 pm
i have tried all that and still no joy ??
any ideas?
daniel_l
on Sep 5, 2005 at 2:15:37 pm
Have you re-installed the application, (or did you copy it over from your previous system? - if you copied it across then it's very unlikely to work)
If you did a fresh install, and it still won't open, then it points towards more serious, system-level problems and I would suggest backing up and doing a fresh, full system install (not an archive install).
