Utility to determine a PAL or NTSC DVD-5 Diskette
COW Forums : DVD Authoring
William McQueen
on Jul 23, 2005 at 11:38:19 pm
Is there any utility out there that can determine if a recorded DVD is either PAL or NTSC; or other process? (There are no labels.) And if they're set to zero region.
Thanksfor your collective wisdom.
Cheers,
Bill in Toronto
David Roth Weiss
Re: Utility to determine a PAL or NTSC DVD-5 Diskette
on Jul 24, 2005 at 10:04:33 am
Bill,
If they don't play in an NTSC player, they're PAL, and if they do their NTSC. Thats the utility...
DRW
George W.
on Jul 24, 2005 at 12:26:45 pm
If you have a PC with a DVD drive that will let you explore the disc, you can use IFOedit to open up the VIDEO_TS.IFO (in the VIDEO_TS Folder). You should see some info that would point you in the right direction...
