Adding subtitle to a project
COW Forums : DVD Authoring
Delphine
on Jun 21, 2005 at 1:44:34 am
I am working on a 35min lenght project. I only need to add subtitles to a 20min portion of the project. I have been able to add subtitles to most ofthe portion but before I am able to complete the task I get the following error messages:
"out of memory"
"an abnormal condition has been detected"
"Unexpected end of data"
"Internal error"
Any advice? What should I do to prevent this messages? How can I complete my project without errors?
Delphine
Roadkill
Re: Adding subtitle to a project
on Jun 21, 2005 at 10:46:39 am
Delphine,
Which authoring application are you using? Are the subtitles created directly in the authoring app itself or are you adding them via a subtitle text script or a subtitle script based on bitmaps?
Delphine
on Jun 21, 2005 at 2:01:36 pm
I use Encore DVD and I created the subtitles in Encore.
Bill Stephan
on Jun 21, 2005 at 3:33:32 pm
What encode rate are you using for picture and sound in your project? If the combined bitrates for your picture and sound are already near the limit, you might not be able to add a subpicture track, each of which adds 0.4 Mbit/sec. to the total bitrate.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
Delphine
on Jun 21, 2005 at 3:44:49 pm
I think I have used 7mbps CBR 1 pass.
Bill Stephan
on Jun 21, 2005 at 7:34:15 pm
What about the sound? The bit rate for each stream of sound and subtitles is in addition to the bit rate for the picture. If you used uncompressed (PCM) audio, you might be pushing your luck if the picture contains spikes of high birate.
Bill Stephan
USA Studios
New York City
Delphine
on Jun 22, 2005 at 6:27:47 am
I encoded my project in Premiere pro using Adobe media encoder and selected the following pre-defined setting:
PAL DV 4x3 high quality 7Mb CBR 1 pass
Audio: PCM
What woud you recommend that I do. Who and where do I compress the Audio
Thanks for the help
Delphine
